Discussion topic: Wifi
This message was authored by: Elliek
Wifi
Wifi keeps dropping. This has been going on since around 11th September. Someone come out to fix the issue around the 19th it worked for around 2 days and since then wifi has been patchy to say the least. I work from home so I need a reliable WiFi network.
Re: Wifi
@Elliek It's time for you to go through the same process again letting sky know that it did not work completely!
