Discussion topic: Wifi
This message was authored by: TheBear2018
Wifi
Internet not working. All lights on correctly but nothing.
Re: Wifi
@TheBear2018
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
