Discussion topic: Wifi
Message posted on 20 Sep 2025 07:57 PM
Wifi
Message posted on 20 Sep 2025 08:06 PM
Re: Wifi
@Pattern
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
