7
This discussion topic has been answered Discussion topic: Wifi
This message was authored by: Vickyb79
Wifi
My wifi dont seem to be working
Re: Wifi
@Vickyb79
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Wifi
@Vickyb79
Re: Wifi
@Vickyb79 What do you see if anything to say it's not working!
Avatar for Vickyb79
Level 0 icon
Re: Wifi
Its says everything is ok
Re: Wifi
@Vickyb79 You should run the link test's that @Daniel0210 has pointed you towards!
Avatar for Vickyb79
Level 0 icon
Re: Wifi
I have done that connection if fine, it saying my WiFi signal is poor, not had any problems with it b4 now
Re: Wifi
@Vickyb79 Try powering off the Hub for 10minutes to see what it does when it goes back on!
Avatar for Vickyb79
Level 0 icon
Re: Wifi
  • I did turn everything off at the mains but only for few minute I will try again but for longer thanks
