Discussion topic: Wifi
This message was authored by: Mikala5
Wifi
My internet ain't working I have rang 2 times in the last hour and u keep getting me to do the **bleep** thing it still ain't working and just befor I say that I get cut off it's getting a joke now been with out internet for a week
Re: Wifi
@Mikala5
In case you’re not aware you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Wifi
@Mikala5 Assuming the service checker in the My Sky app run over a mobile connection is not telling you there is a known fault affecting your line call Skyband hold to speak to an agent and report the fault.
Re: Wifi
@Mikala5 you will just have to persist as there is not more you can do!
