Discussion topic: Wifi
Message posted on 25 Aug 2025 10:38 AM
Wifi
Why does your tests keep saying the WiFi looks good yet I cannot connect to the internet even when I am sitting in the same room.
it also says it looks good when an orange light is either flashing or a green light disappears which clearly shows an issue.
Message posted on 25 Aug 2025 10:52 AM
Re: Wifi
Not our tests. In case you’re not aware you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update.
If there still aren't any then try running the line test here
Message posted on 25 Aug 2025 11:22 AM
Re: Wifi
Hi Daniel,
Thanks for your reply. I am aware this is not sky customer services however reading back my message I can see the chosen words that have been used have been used incorrectly but thanks for pointing it out incase I wasn't aware.
the test I have been running is through the my sky app but it's annoying that it says nothing wrong everytime when clearly there is.
i will give your link a try, thanks again.
