Discussion topic: Wifi
This message was authored by: Dillon666
Wifi
Hi
I keep having to turn my WiFi box off and on so the WiFi will work,it ise to be the odd time,now it's every second day
Can you look into this,it's very frustrating 😑
Cheers
Dillon 🍻
Re: Wifi
@Dillon666
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
