Discussion topic: Wifi
Message posted on 11 Jul 2025 10:22 AM
Wifi
The internet is not working properly. I've had trouble since yesterday. The lights on the router are: green, yellow, green, yellow. Please resolve the issue as soon as possible.
Message posted on 11 Jul 2025 10:57 AM
Re: Wifi
@AndraVoiculet
You aren’t contacting Sky Customer Services here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
Your exact duplicate thread has been removed as you have this one.
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
