Discussion topic: Wifi
This message was authored by: Randomguy123
Wifi
WiFi has randomly gone out and it won't game any signal even though my booster and wires are perfectly fine
Re: Wifi
@Randomguy123
When broadband is lost between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband still isn’t working after 7am and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
