Discussion topic: Wifi
Message posted on 21 Jun 2025 12:45 PM
Wifi
Message posted on 21 Jun 2025 12:49 PM
Re: Wifi
@Michellestretto
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
