Discussion topic: Wifi
Message posted on 21 Jun 2025 06:48 AM
Wifi
Message posted on 21 Jun 2025 07:10 AM
Re: Wifi
We can't investigate this. This is predominantly a customer led discussion forum where Sky customers are available to help other customers. You aren’t contacting Sky Customer Services by posting here.
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
