Discussion topic: Wifi
This message was authored by: Rob_k
Wifi
How do I get a signal down to my garden it's 30 ft long don't really want to run a cable
Re: Wifi
@Rob_k Why do you want to run the signal down there, give us a hint!
Avatar for Rob_k
Re: Wifi
  • I have a bar with alexa
Re: Wifi
@Rob_k Do you have mains power from home to your bar, and is speed a major must have it all out at your bar? If not powerline from the Hub to the bar area will probably work fine, speed will not be up there no matter what! Also do you need both wireless and wired at the bar?
