Discussion topic: Wifi
Message posted on 28 May 2025 11:11 PM
Wifi
Check my wifi
Message posted on 29 May 2025 03:26 AM
Re: Wifi
@Emma436 wrote:
Check my wifi
@Emma436
You are NOT contacting Sky Customer Services by posting here.
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
