Discussion topic: Wifi
Message posted on 14 May 2025 04:11 PM
Wifi
Message posted on 14 May 2025 04:44 PM
Re: Wifi
@-Chrissy17- wrote:
WiFi dropping in and out .
@-Chrissy17-
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 14 May 2025 04:50 PM
Re: Wifi
Same thing happens to me. Line tests obviously show that nothing is wrong - because it only works when there is a connection!
This has been happening to me for weeks now, at the moment it's droppint out every 15-20 minutes for about 3-4 minutes each time. I won't be renewing my broadband service at the end of the month.
