Discussion topic: Wifi
This message was authored by: Darren60
Wifi
WiFi hub not working need a new one. WiFi signal is extremely poor.
Re: Wifi
@Darren60
If your hub isn't working then you would have no wifi signal but as you said you do then try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
