Discussion topic: Wifi
This message was authored by: Barlow199222
Wifi
On WiFi router ..
lights in order
power - green light
internet - no light
wi-fi - green light
voice - orange light
WiFi is not working on devices
Re: Wifi
@Barlow199222
▪️I AM NOT A SKY EMPLOYEE ▪️
