Discussion topic: Wifi
Message posted on 28 Feb 2025 08:10 PM
Wifi
My Wi-Fi is simply horrible, on the second floor of the house it never works and now on the ground floor too, I would like you to check what is happening, because I am not happy with it, it is causing me a lot of inconvenience and losses
thank you
Message posted on 28 Feb 2025 08:56 PM
Re: Wifi
We can't check it as we are customers too. You aren’t contacting Sky Customer Services on here.
If you’re still having problems you may need to call Sky to report it (dial 150 free from your Sky Talk landline [if it’s still working]).
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
