Discussion topic: Wifi
This message was authored by: Seans1
Wifi
Sky service checker says internet is working but noting will connect
Re: Wifi
@Seans1
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
