Discussion topic: Wifi
Message posted on 12 Feb 2025 11:10 AM
Wifi
Message posted on 12 Feb 2025 11:16 AM
Re: Wifi
@Anthony87-
In addition~
▪️ Any engineer visit that’s required is still likely to be delayed due to the disruption from the recent storms.
▪️ This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
