Discussion topic: Wifi
This message was authored by: Ellarose007
Wifi
Our WIFI says it is good when I ran the test on your website. It really isn't though! Our phones are always reverting to 5G and the teles keep disconnecting from the internet. What can I do please?
Re: Wifi
@Ellarose007 if your phones are switching to use mobile data check their settings as iPhones and some Android phones have a setting which does this if mobile signal is faster which can be the case if yiu have goid 5g reception. On iPhones its called WIFi assist and is at the bottom of ghe mobile settings.
However if you find you TV's cannot stream you may simply need additional WiFi kit as in many homes a single hub is not sufficent to give coverage in every room. Sky will sell you their WiFi Max bundle thst can provide up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or you can use your own WiFi kit if you prefer.
Avatar for Ellarose007
Re: Wifi
Hi there. I have followed the link to try and get the extra boosters that you mentioned but it is saying they are not available in my area????
