6
This discussion topic has been answered Discussion topic: Wifi won't accept password
This message was authored by: Deborahjf
New customer and cannot add devices to wifi.  Says check password.  Have done. Have also reset to factory settings
Avatar for Deborahjf
This message was authored by: Deborahjf Answer
Re: Wifi won't accept password
Thanks but eventually had to spend an hour on the phone with them and it wasn't me I need a new hub,beingsent. Not a great start!
@Deborahjf Just be carefull when you enter the password to the devices, especially with o O 0, i 1 etc look very similar!
Retyped many times with others dictating so definitely not a typo
@Deborahjf Have you managed to get ONE single device to connect on the wireless wi-fi password wise!
Password label is it on the back off the hub, underneath on the base off the hub, and you should also receive a card in the box with ALL the details, take a quick look whatever one you have matching each other!
Can't get any device to pair. Wifi is available but not with the password provided.  Started everything up this morning as a new customer with a tv and broadband package.  Everything working apart from trying to add phone or tablet.
@Deborahjf Have a look at the two following links!.
sky connecting devices
https://www.sky.com/help/articles/connect-devices-to-broadband-start
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
