Discussion topic: Wifi turns off
Message posted on 26 Jun 2025 01:59 AM
Wifi turns off
Message posted on 26 Jun 2025 06:09 AM
Re: Wifi turns off
@Abdul14 11pm is early for most maintenace activity but loss of connection after midnight is often down to networks being taken down for essential work. Otherwise look at the lights on your Sky hub as thry can tell you what is happening see https://www.sky.com/help/articles/hub-lights-explained-start
Message posted on 26 Jun 2025 02:57 PM
Re: Wifi turns off
That's fine but I be playing games at night so around the time that happens and I barely get to play with family and friends online. If it keeps happening I will have no choice but to go back to Vodafone as the only problem I had with them was cost.
If its costing more and won't turn off as much then I will consider going back to them or a different provider
Why can't this maintenance thing be happening like 4 - 6 in the morning?
Message posted on 27 Jun 2025 11:52 AM
Re: Wifi turns off
So if maintenance is around 11pm. Why is my WiFi turning off during the day? This is the third time it has turned off during the day in the last 2 days. If it gets worse In the next week I'll be moving back to Vodafone. I'll gladly pay double if it doesn't turn off and its been off for the past 20 mins. I'm using my own data to write this.
The sky app doesn't help as it doesn't show me what is currently happening but instead shows the WiFi working 35 mins ago. When I try checking, it says everything is good 35 mins ago even though the WiFi isn't working off and it isn't telling me what is happening at the moment
