Discussion topic: Wifi stopped working
Message posted on 22 Feb 2026 04:35 PM
Hello. My wifi was working fine and then suddenly stopped working complete. I have disconnected the box multiple times but it's still not working. What should I do? Thank you.
Message posted on 22 Feb 2026 04:38 PM
Re: Wifi stopped working
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
