Discussion topic: Wifi still not set up
This message was authored by: Tyle
Hello we had a sky engineer out on the 14th and still nothing the engineer said to my partner it'd be on within 24 hours and this is a massive inconvenience to me if this poor service continues I'll be changing provider
Re: Wifi still not set up
@Tyle
Are you sure the engineer that came installed the fibre cabling and ONT reaady for your activation, if you are not sure then what shows here regarding your order:
https://www.sky.com/ordertracking
