Discussion topic: Wifi speed
Message posted on 12 Jan 2026 04:51 PM
Wifi speed
Hello our wifi speed just briefly is not good enough. My son has done a test on his phone and the download speed is 2.6 mbs it's not good enough at all. Granted my other son has wired but his is 457 mbs if this is not improved im sorry but im going to have to look somewhere else for wifi
Message posted on 12 Jan 2026 05:31 PM
Re: Wifi speed
@TracyVellacott you are notvtalking to Sky by posting in the forum. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
