3
This discussion topic has been answered Discussion topic: Wifi signal
This message was authored by: Russellevans
Wifi signal
Trying to talk to someone as the virtual system is no good.
just had Sky broadband fitted the only issue is that it doesn't reach all parts of the house so want to know if there is an option of boosters as I need it for my office.
i have done all the normal things of position etc
This message was authored by: Highlinder Answer
Re: Wifi signal
@Russellevans  You will be looking for pods for boosting the Wi-Fi signal. Give Sky a call and they should be able to help getting one sent out for you.
Just dial 150 on your landline and listen through the voice prompts.
Re: Wifi signal
@Russellevans  Which router did Sky send as part of your service for broadband from the link below.
Avatar for Russellevans
Re: Wifi signal
Sky Max Hub
Re: Wifi signal
