Discussion topic: Wifi setup
Message posted on 03 Oct 2026 11:24 AM
Wifi setup
Message posted on 03 Oct 2026 11:27 AM - last edited: 03 Oct 2026 11:28 AM
Re: Wifi setup
@GraemeFletcher wrote:
I have recently "upgraded" my wifi to Max. (As it offered parental controls) I live in an old house with thick walls thus I have installed this together with the three sky boostert that I already had from previous sky hub/router.
Those won't work properly with a Max Hub.
Max has its own WiFi 'pods'.
Message posted on 03 Oct 2026 11:29 AM
Re: Wifi setup
As you already have 'Wi-Fi Max', Sky will loan you up to 3 booster pods. Call Sky to arrange the first one. Just dial 150 free from your Sky Talk landline.
To add a second or third pod it requires an engineer visit to check your set up.
Message posted on 03 Oct 2026 11:37 AM
Re: Wifi setup
Thanks.. is there an alternative number if not using sky talk landline?
I already have 3 original sky boosters..but would be very happy for a engiyvisit too.
Message posted on 03 Oct 2026 12:11 PM
Re: Wifi setup
For your information you do have a Sky Talk landline as it's bundled with your broadband package but if you have chosen not to connect an actual handset that's fine and entirely your choice.
In the future you can plug in a cheap handset when you need to call Sky (dialling 150 free) if the Sky Talk side of things are working..
Call Customer Services by dialling 150 (free) from a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn't allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls start automated (aka 'the bot') which may offer you an online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
