2
This discussion topic has been answered Discussion topic: Wifi replacement card
This message was authored by: Jules171
Is it possible to get a new replacement WiFi card for my router mislaid mine
Re: Wifi replacement card
@Jules171
Do you mean the card that your Wifi network name and password was on, if so this is also on the broadband hub itself.
@Jules171
@Jules171 No card will be supplied, either back or bottom off the sky Hub, suggest you capture a mobile picture so you have it!
