Discussion topic: Wifi range
This message was authored by: Conal92
Message posted on 07 Aug 2024 09:24 PM
Wifi range
My wifi router is plugged into my bt open reach hub by my front door and the signal doesn't reach certain places in my flat is there anyway I can move the open reach device or anything else I can do to sort this problem out
Find out more
Message posted on 07 Aug 2024 09:44 PM
Re: Wifi range
@Conal92 you can often pay to get a master socket moved, full fibre ONTs are more difficult. Initially talk to Sky as they can explain the options.
Message posted on 08 Aug 2024 02:34 AM
Re: Wifi range
Thanks for the reply I'll get in touch with sky
