Discussion topic: Wifi quality
Message posted on 26 Feb 2026 01:58 PM
Wifi quality
The broadband and WiFi are coming up as working well with good connection. But the WiFi is regularly dropping out and and breaking up.
Message posted on 26 Feb 2026 02:42 PM
Re: Wifi quality
@ChloeRH Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Message posted on 26 Feb 2026 04:39 PM
Re: Wifi quality
I have the ame problem. does this mean our money is gone?!
Message posted on 26 Feb 2026 05:56 PM
Re: Wifi quality
To getvextendrrscfrom Sky you will need to buy WiFi Max but Sky often discount the product. My own solution was to buy a cheap third party system which has paid for itself more than twice over.
