Discussion topic: Wifi problem
Message posted on 13 Jun 2026 03:00 PM
Wifi problem
Message posted on 13 Jun 2026 04:07 PM
Re: Wifi problem
@AJa wrote:
We have had ongoing wifi issues for a while now. Having to reset constantly with the WPS button. Internet speeds are terrible.
WiFi speeds or speeds to the actual router?
Have a look at the following to see if they can resolve your problem easily if it's wifi, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
