Discussion topic: Wifi problem
This message was authored by: Ade102
Wifi problem
My laptops cannot locate the wifi
Re: Wifi problem
@Ade102
What lights are lit on your broadband hub ?
Avatar for Ade102
Re: Wifi problem
Green.
None of my two laptops and tablet can locate the WiFi- just 4ft away.
Re: Wifi problem
@Ade102 What hub? Take it that all other devices connected ok but your laptops are the only issue, if those have Ethernet ports do they connect fine via that method! What is the tablet that you are trying to connect, also the devices link for older connection below.
https://www.sky.com/help/articles/connect-devices-to-broadband-start
