Discussion topic: Wifi permanently slow since ever having it installed
This message was authored by: Bcd91
The wifi has been slow ever since it was installed, emails never load, no images etc.
When I check the status it always says 'looks like there's a problem' (see image) but then when I go further it says everything's fine.... but it definitely isnt!
Re: Wifi permanently slow since ever having it installed
Hi @Bcd91 Please post your router stats
https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717/jump...
I am NOT a Sky Employee
Avatar for Bcd91
Thank you @jamesn123 please see below 🙂
..... it won't seem to let me upload an image / screenshot, and when i copy and paste the table the format disappears....
Router Statistics
System Up Time: 631:08:11
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 94587244 200549662 0 1039744 1372709 631:06:05 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 39129970 11456646 0 14845 10340 631:06:22 WLAN (5 GHz) Up 167447510 83384816 0 0 0 631:06:21
Broadband Link Downstream Upstream Connection Speed 40000 kbps 7492 kbps Line Attenuation D1(20.5 dB) , D2(57.1 dB) , D3(88.6 dB) U0(7.2 dB) , U1(44.2 dB) , U2(0.0 dB) Noise Margin 7.3 dB 5.8 dB
Poll Interval:
Seconds (at least 3s):
@Bcd91
There is nothing on your stats that suggest a problem other than you have everything connected via WiFi and nothing cabled.
How many devices do you have?
Have you tried the WiFi troubleshooting steps here; https://www.sky.com/help/home/broadband/my-broadband-speed/no-connection-slow-wifi/articles/broadban...
