Discussion topic: Wifi password
Message posted on 21 Apr 2025 11:58 AM
Wifi password
Blink camera won't accept WiFi password. When I'm putting it in correctly
Message posted on 21 Apr 2025 12:01 PM
Re: Wifi password
My blink camera is not accepting my WiFi password
Message posted on 21 Apr 2025 12:22 PM
Re: Wifi password
@WiFipassword If you are 100% certain that the password is correct what is the error message that you get when the camera does not accept?
Message posted on 21 Apr 2025 12:29 PM
Re: Wifi password
The says unable to connect and the blink module goes on standby
Message posted on 21 Apr 2025 12:32 PM - last edited: 21 Apr 2025 12:34 PM
Re: Wifi password
@WiFipassword What sky router do you have, what Blink Camera and or Module is it that you are dealing with. Is this a new camera install or has it been on another system before? And does Blink Forum have any ideas....
Would you also uncheck the answered as this has not been done.
Message posted on 21 Apr 2025 12:34 PM
Re: Wifi password
They new cameras. The module I'm trying to connect to is a blink module 2. I haven't been on the blink forum yet.
Message posted on 21 Apr 2025 12:38 PM - last edited: 21 Apr 2025 12:51 PM
Re: Wifi password
@WiFipassword Detail is what is required, will take a quick look at your current response, but do read the request, what sky router do you have?
Sync Module 2 FAQ — Blink Support
It is also a 2.4Ghz band connected device, so that alone depending on how you have you sky router/type etc may require to be adjusted. Take a look at the Blink Forum it may be nothing to do Router wise....
You can also type Blink Module 2 into the search bar for the Forum!
Message posted on 21 Apr 2025 12:56 PM
Re: Wifi password
Sorry the router is sky.
Message posted on 21 Apr 2025 12:58 PM
Re: Wifi password
@WiFipassword I have posted up some links for you to work through.
