1
This discussion topic has been answered Discussion topic: Wifi outage
This message was authored by: Jules1922
Wifi outage
WiFi keeps dropping
Re: Wifi outage
@Jules1922
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Re: Wifi outage
@Jules1922
