Discussion topic: Wifi off
Message posted on 12 Jun 2026 01:29 AM
Wifi off
Message posted on 12 Jun 2026 01:38 AM
Re: Wifi off
Exactly the same issue here. The service checker is useless too.
Message posted on 12 Jun 2026 05:01 AM
Re: Wifi off
@gogsy321
When there are any broadband issues between midnight and 7am it could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided.
See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
Message posted on 12 Jun 2026 08:52 AM
Re: Wifi off
WiFi not working
Message posted on 12 Jun 2026 09:47 AM
Re: Wifi off
@VandanaVaryani
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
