Discussion topic: Wifi not working
This message was authored by: Jules125125
Wifi not working
Wifi not working
Re: Wifi not working
@Jules125125
When there are broadband issues between midnight and 7am it could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided.
See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
Avatar for Jules125125
Thanks for replying. Unfortunately it went out around 9:30pm. All lights are green on box and when doing the test online it says everything is working fine. But nothing is connecting and it says no internet when trying to connect devices. My sky TV also isn't working due to no internet. This is no good.
@Jules125125
Start by using this link again to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
