Discussion topic: Wifi not working
This message was authored by: sebcomber1
Wifi not working
Sky tests say everything is ok with wifi. However nothing is able to connect!!!
Re: Wifi not working
@sebcomber1
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
