Discussion topic: Wifi not working
Message posted on 08 Jun 2026 02:09 PM
Wifi not working
Wifi not working. Checker says all should be OK. Router just slowly flashing green.
Message posted on 08 Jun 2026 02:13 PM
Re: Wifi not working
@Pet6
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
