Discussion topic: Wifi not working
This message was authored by: Smiffy74
Wifi not working
wIFi is not working.
Re: Wifi not working
@Smiffy74
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
