3
This discussion topic has been answered Discussion topic: Wifi not working
This message was authored by: Miss+Brohan
Wifi not working
My wifi decided to stop working a few mins ago. We have done the usual tests and runs including turning it on and off and checking all cables etc. Not working. Checked on tv and it is ticked beside the connection to router but not internet
Avatar for Miss+Brohan
This message was authored by: Miss+Brohan Answer
Re: Wifi not working
Thank you but I had done all of that before writing on here. It seems to be a sky issue that has since resolved itself. Thank you
@Miss+Brohan   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
This message was authored by: Mob90
We're the exact same. So annoying because when I troubleshoot it via my sky it tells me the problem is with my sky q box, but it is due to a lack of internet connection.  I feel like this may be a DNS issue, and so something that just needs to be rectified on Sky's end.
