Discussion topic: Wifi not working
This message was authored by: helpmeplease23
Wifi not working
The wifi keeps dipping in and out. We are having to use our data.
Re: Wifi not working
@helpmeplease23
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
