Discussion topic: Wifi not working
Message posted on 30 Apr 2026 04:20 PM
Wifi not working
Message posted on 30 Apr 2026 04:23 PM
Re: Wifi not working
@Tashaaw
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
