Discussion topic: Wifi not working
Message posted on 25 Mar 2026 01:40 PM
Wifi not working
Says there is no fault with my internet but nothing will connect to wifi
Message posted on 25 Mar 2026 01:49 PM
Re: Wifi not working
@Jordan134
Message posted on 25 Mar 2026 01:55 PM
Thevfirstbthing to try if you are yet to do this is to reboot your broadband hub at the mains then after powering it up give it a few minutes to fully load before trying again to see if your devices will now connect.
