Discussion topic: Wifi not working
Message posted on 27 Feb 2026 07:44 PM
Wifi not working
Message posted on 27 Feb 2026 07:52 PM
Re: Wifi not working
@RazvanStoica
Message posted on 27 Feb 2026 09:21 PM
Been steadily getting worse WiFi after 9pm for weeks
now tonight middle light of hub dead
Message posted on 27 Feb 2026 09:41 PM
Try running this line test to see if it finds any faults:
