Discussion topic: Wifi not working
Message posted on 22 Feb 2026 08:03 PM
Wifi not working
The wifi has been down for around 5 hours now. The internet light is flashing orange, all the other lights on the box are green. I have turned the router off and on multiple times and reset the router also. There has been no change.
Message posted on 22 Feb 2026 08:06 PM
Re: Wifi not working
@Jack282
