Discussion topic: Wifi not working
Message posted on 14 Jan 2026 07:18 PM
Wifi not working
Hi Wi-Fi has dropped out and we have two amber lights for internet and phone
and two green
wifi checker came out ok and broadband so not sure what the issue can be
wr have reset it and all the connections are fine
please help thanks
Message posted on 14 Jan 2026 07:26 PM
Re: Wifi not working
@RT1982
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
