Discussion topic: Wifi not working
This message was authored by: DarrenBish
Wifi not working
Hi had my sky broadband fitted yesterday and all was working fine until about 11am today when the   red light came on the open reach box and the router. I have trying powering it all down and reseting but the red light keeps coming on
Re: Wifi not working
@DarrenBish
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
@DarrenBish
Not a good start.
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
