Discussion topic: Wifi not working
Message posted on 11 Dec 2025 10:47 AM
Wifi not working
Message posted on 11 Dec 2025 12:04 PM
Re: Wifi not working
@Mikekidson
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
