Discussion topic: Wifi not working
Message posted on 03 Dec 2025 05:46 PM
Wifi not working
Hi, my has gone down and I've tried to reboot 2 times with no luck
Message posted on 03 Dec 2025 05:48 PM
Re: Wifi not working
@Sophienoad
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
